VPN Client - Conenction made but not able to access resources
Answered Question
Apr 16th, 2010
I have two sites, Site A with a 5510 firewall and Site B with a user with a basic internet connection.
I need that user to be able to access PC's and servers here.
I created a Remote Access VPN called Bon and the user can establish connection to this on Site B.
They get an ip address and dns but no default gateway.
I am unable to ping anything on the 10.255.0.0/16 network or access any of the servers.
I will post the config and maybe someone could show me what I am missing!
Thanks in advance
Correct Answer by Jennifer Halim about 7 years 2 weeks ago
I would not recommend configuring ip pool in the same subnet as your internal network. Please configure a different ip pool subnet.
However, with the current configuration, you are missing NAT exemption for those subnets:
access-list inside_nat0_outbound extended permit ip 10.255.0.0 255.255.0.0 10.255.11.0 255.255.255.0
Hope that helps.
Correct Answer
Jennifer Halim Fri, 04/16/2010 - 04:46
  • Cisco Employee,
Hope that helps.
drikilbride Fri, 04/16/2010 - 05:41
Thanks for that, I will configure the different pool now!
Related Content
