PVDM2/Conference Capacity Question
Answered Question
Apr 16th, 2010
A PVDM2-48 module has 3 DSP's on it.  Each DSP can accomodate (2) 32-party conferences.  If I configure the dspfarm with a maximum of 32 parties per conference and a maximum of 6 sessions, does that mean that no matter how many parties are in a conference, I'll only be able to have 6 active conferences?  Or, if there are only 8 parties in a conference, can I have 24 conferences?  Is reducing the maximum participants the only way to increase the number of available conferences?
Correct Answer by Rob Huffman about 6 years 10 months ago
Hi Jordan,
With Conferencing, 6 sessions means exactly that
When you configure the max-particpants @ number "X" this means that
the conference reserves this capacity "X" for each session. Reducing the
max-participants number is the only way to increase the max-sessions
as you nicely noted.
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 04/16/2010 - 05:25
Hi Jordan,
Cheers!
Rob
