OSPF routing issue
Answered Question
Apr 16th, 2010
Can somebody please help
I have cisco 3620  internet firewall router . the router cpu utilization becaus eof ospf process.
62   109947332   1642150      66953 96.84% 45.86% 44.08%   0 OSPF Router
Can you let me knwo what needs to be done to clear this issue
its really urgent
Correct Answer by rupam_chakra1983 about 7 years 3 months ago
Plz check your neigbor link wherether they are fluctuating and check for error in connected interface.
Seems that it has many neighbors and neignborship is continously fluctuating.
May be this help us, as this is a common problem
Overall Rating: 5 (1 ratings)
Correct Answer
rupam_chakra1983 Fri, 04/16/2010 - 06:27
dodusbacker Fri, 04/16/2010 - 07:28
I checked that at first stage but that is fine. there is no fluctuation.
routing table is getting converged at every 3 minutes
and this is asbr for that area
Mark Rigby Fri, 04/16/2010 - 06:51
As a drastic measure you could issue "clear ip ospf process" however this would reset all adjacencies and potentially cause a temporary outage whilst the network reconverges.
dodusbacker Fri, 04/16/2010 - 07:26
I cannot do that as  there is anothert crtical servers running on it.
and there is only  two links to tis router
