Blackberry MDS and UC560
aschertz
From my partner:
We want to use our Blackberry MDS with the UC560
For the UC560 can we use our Blackberry and then from the Blackerry can we then transfer to another extension?"
Thanks - Art
Hi Art,
This is not supported. For true mobility integration, including unified messaging features, a partnership with a Service Provider is typically needed. Right now, we only have a couple worldwide that offer RIM integration.
Marcos
David Trad
Hi Art,
I haven't worked with this before, so all I could do for you right now is find any information out there available, hopefully someone else is able to be more specific.
http://newsroom.cisco.com/dlls/2009/prod_050409.html
http://na.blackberry.com/eng/services/blackberry_mvs/cisco.jsp
http://news.techworld.com/mobile-wireless/115301/cisco-adds-blackberry-to-ip-phone-system/
These are only news report, nothing earth shattering, but i hope it gives you some insight.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
