Software distribution problem with RME 4.2 regarding flash size
b001348
Hello I'm updating the software on about 200 3750 stacks. During the verification process I'm used to get a warning with the messages swim1132,1201 and 1106. But jobs run then successfully.
But sometimes the verification step fails with the SWIM1200 error. That is a litte strange because all the switches have the same flash size of 15998976 bytes.
The error messages are in the attachment.
I woult be very happy, if somebody can give me an advice.
Markus Schwendimann
Basel, Switzerland
Joe Clarke
This is CSCsu49349.  The bug is fixed in RME 4.3.  The workaround is to go to RME > Software Mgmt > Software Repository, then click on the name of the image.  Reduce its required flash size down one setting (i.e. make the requirement 8 MB).  This will allow the image to deploy properly.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Hi Joe
Thanks for the tip but ....
I tried to change the "minimum flash value" in der sw repository. But it doesn't work. If I change the value,click ok and then click again on the name of the image then I see still the old value. I do that with admin rights.
Markus
You need to click the Update button in the file attributes dialog.
Many thanks, it's all ok now. The obvious will always be easily overlooked.
Kind regards, Markus
