WLC 4400 - 5500
Answered Question
Apr 16th, 2010
In the Wireless LAN Controller 4400 series the configuration was not automatically synchronized between the same group of mobility of controllers, the configuration was done manually in each WLC, In the 5500 WLC is the same or the configuration is synchronized between them automatically?
Correct Answer by Rob Huffman about 7 years 1 week ago
Hi Ricardo,
Hope all is well my friend
With the 5500 series of WLC's the config's are NOT
synchronized between them automatically. Same as the 4400's.
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
EDIT: Dan ...you have trumped my hapless typing skills as usual. +5 my friend!!
Overall Rating: 4.8 (3 ratings)
dancampb Fri, 04/16/2010 - 06:12
  • Cisco Employee,
Configurations are not syncronized between controllers automatically.  You could setup a config group in WCS to help make sure all of the same config templates are pushed to all the controller.
Correct Answer
Rob Huffman Fri, 04/16/2010 - 06:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ricardo,
Cheers!
Rob
