Unity restoration [help req]
Apr 16th, 2010
My client is using Cisco Unity 4.0 Build 4.0(5), Lotus Notes 6.5. I want to restore backup for the client using DiRT backup. Can any one guide me step by step procedure for the backup beacuse i have no expertise in Unity.
SJ
Overall Rating: 5 (1 ratings)
SJ SJ Fri, 04/16/2010 - 22:56
Thanks alot man! i'll go through and let u know if there are any queries.
SJ
SJ SJ Tue, 04/20/2010 - 23:16
I am getting the attached error in the Cisco Unity 4.0 Message Store Configuration Wizard. Please help resolve the error
David Hailey Wed, 04/21/2010 - 05:43
  • Purple, 4500 points or more
The error is fairly straightforward.  Have you installed DUCS on the server and, if so, is it the exact same version as was installed before?
Hailey
