Bandwidth usuage in WAN interface of a router
Answered Question
Apr 16th, 2010
I want to measure the bandwidth used by particular network or particular PC through router WAN interface. I guess we can use Netflow apart from this is there any other options to measure.
Hari
Correct Answer by Giuseppe Larosa about 7 years 3 months ago
Hello Hari,
netflow is probably the best solution but it requires some effort
for getting simple data you can use ip accounting output-packets in interface configuration mode, and then sh ip accounting to see results.
There is no aggregation of data per specific source and you should do this in some way after having exported the show output
NBAR can be useful too.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Fri, 04/16/2010 - 09:29
  • Hall of Fame,
    Founding Member
Hello Hari,
Hope to help
Giuseppe
