Setting New Ipsec Tunnel "3Des, Md5 " On Cisco 877W To Netgear Fvs338
Apr 16th, 2010
Pls help . i got SDM 2.5 running on my machine ..with default setting connected....New .. nothing setting yet...
I need to setup this vpn from one of the sites with 192.168.47.0 address to HQ 192.168.100.0
CSCO11177557 Fri, 04/16/2010 - 11:28
thanks for the reply....
You mean it will be easier with just cisco gears, ...soo i can't get it work between cisco 877w and netgear fvs338.
cheers;
Federico Coto F... Fri, 04/16/2010 - 12:33
  • Green, 3000 points or more
I'm not saying is not going to work.
If the NetGear supports the standard IPsec there's no reason why it would not work.
The link was to show you the configuration example on setting a L2L IPsec tunnel on a Cisco IOS device.
Obviously, you can establish the tunnel between Cisco devices as well.
Federico.
