Call Waiting Tone Question
Can you please assist in following up with this question for me?  Our current ATA is configured for Call Waiting tone with these parameters (config template can be attached if needed):
<Default_CWT_1_ ua="na">1</Default_CWT_1_>
<CWT1_Cadence ua="na"> 31.2(.3/10.1)</CWT1_Cadence>
<CWT_Frequency ua="na">440@-22</CWT_Frequency>
Per the bellcore spec, is this the same as? 440@-22;31.2(.3/10.1/1)
My main confusion is around the CWT1_Cadence value since it is missing the tone index parameter; ie: [email protected];repeated times(on time/off time/tone index).  Is there a shorthand value since there is only 1 tone listed in the CWT_Frequency parameter?
Adam
nseto Tue, 05/11/2010 - 17:01
Dev's response to your question is below.
·         ToneScript – A mini-script that specifies the frequency, level and cadence parameters of a call progress tone. May contain up to 127 characters. Syntax: FreqScript;Z1[;Z2]. The section Zi is similar to the Si section in a CadScript except that each on/off segment is followed by a frequency components parameter: Zi = Di(oni,1/offi,1/fi,1[,oni,2/offi,2/fi,2 [,oni,3/offi,3/fi,3 [,oni,4/offi,4/fi,4 [,oni,5/offi,5/fi,5 [,oni,6/offi,6/fi,6]]]]]), where fi,j = n1[+n2]+n3[+n4[+n5[+n6]]]]] and 1 < nk < 6 indicates which of the frequency components given in the FreqScript shall be used in that segment; if more than one frequency component is used in a segment, the components are summed together.
Example   1: Dial   Tone
350@-19,440@-19;10(*/0/1+2)
Number of Frequencies = 2
Frequency 1 = 350 Hz at –19 dBm
Frequency 2 = 440 Hz at –19 dBm
Number of Cadence Sections = 1
Cadence Section 1: Section Length = 10 s
Number of Segments = 1
Segment 1: On=forever, with Frequencies 1 and 2
Total Tone Length = 10s
Example   2: Stutter   Tone
350@-19,440@-19;2(.1/.1/1+2);10(*/0/1+2)
Number of Cadence Sections = 2
Cadence Section 1: Section Length = 2s
Segment 1: On=0.1s, Off=0.1s with Frequencies 1   and 2
Cadence Section 2: Section Length = 10s
Total Tone Length = 12s
Example   3: SIT   Tone
985@-16,1428@-16,1777@-16;20(.380/0/1,.380/0/2,.380/0/3,0/4/0)
Number of Frequencies = 3
Frequency 1 = 985 Hz at –16 dBm
Frequency 2 = 1428 Hz at –16 dBm
Frequency 3 = 1777 Hz at –16 dBm
Cadence Section 1: Section Length = 20s
Number of Segments = 4
Segment 1: On=0.38s, Off=0s, with Frequency 1
Segment 2: On=0.38s, Off=0s, with Frequency 2
Segment 3: On=0.38s, Off=0s, with Frequency 3
Segment 4: On=0s, Off=4s, with no frequency   components
Total Tone Length = 20s
nseto Thu, 05/27/2010 - 16:52
The Default CWT parameter is referencing which CWTnumber Cadence to use.  Since 1 is in Default CWT, it would use the freq setup in CWT1 Cadence. So from what you've written, it looks like match.
