04-16-2010 01:56 PM - edited 03-11-2019 10:33 AM
Hi All,
Can any one help me to know how to deploy a the ASA-CSC10-USR-500 software for the ASA 5500 series?
Thanks in advanced,
Ahmed
Solved! Go to Solution.
04-17-2010 03:08 PM
You mean do the Trend CSC work with software on the ASA?
No, that cannot be done, yet at least.
The SMTP, POP3, HTTP, FTP scanning and filtering on an ASA can only by done if you have a CSC module.
You can use url filtering with Ironport, N2H2 or websense and the ASA without having to buy more hardware but you still need to buy software.
I hope it helps.
PK
04-16-2010 03:21 PM
We have a very good guide for a CSC initial config https://supportforums.cisco.com/docs/DOC-5668
And one very good for upgrading the module https://supportforums.cisco.com/docs/DOC-1323
I hope it helps.
PK
04-17-2010 02:41 PM
Hi PK,
Hope you are fine,
Thanks for your soon reply, I need your help to be sure that this deployment guide talk about Hardware module, so is there any chance to use a bundle (software) module instead of the hardware module?
Please correct me if I wrong.
Thanks in advanced,
Ahmed
04-17-2010 03:08 PM
I hope it helps.
PK
04-17-2010 04:18 PM
Hi PK,
Thank you for your soon reply, it’s clear now, I need your help to find which module are suitable for the ASA 5520?
Thanks In Advanced,
Ahmed
04-17-2010 04:23 PM
The CSC modules supported on the 5520 platform are either the CSC-SSM-10 or the
CSC-SSM-20
More information
Federico.
04-18-2010 02:22 AM
Dear Federico,
Hope you are fine, thanks a lot for your reply, the document was very useful to me.
Kindly Regards,
Ahmed
04-18-2010 02:25 AM
Hi PK,
Thanks for your great support, I appreciate your effort, the documents that you send it to me was very useful.
Kindly Regards,
Ahmed
