cisco891w-agn router
Apr 16th, 2010
Just got the 891 and I am unable to access the 'Internal Access Point Application'. I am assuming this application has the same look and feel as a 1230 ap through the browser. If I am in the Cisco CP Express application, choose wireless, towards the bottom it allows me to click a link 'basically hyper-linking me through the BVI1 interface. I login, and a page comes back with a 'Enter' button and the Cisco Copyright info, though if you select the enter button, you get web page errors ( 'undefined' is null or not an object).
From the router cli, I can session to the embedded ap with no problem. I was just hoping I could access the web gui of the AP in order to config all my SSID's, VLAN, AAA Auth. ect...
Router IOS = 12.4(22)YB
AP IOS = 12.4(21a)JA1
Any help on this would be greatly appreciated.
Surendra BG Mon, 05/03/2010 - 08:04
Hi Jeff..
We are hitting a Bug on 12.4(21a)JA1.
The resolution is to download the AP IOS 12.4(10b)JDA3 from the web site and upgrade the AP module using the command..
#archive download-sw / force-reload/ overwrite tftp:/// Hoping you have pointed the image in the tftp server>
Then try browsing to the BVI interface ip address..
This will for sure solve your issue.
