How to match tunnel-group with ASA 8.2 and VPN Client IPSec auth using Digital Certificates with Microsoft CA
fernandoaguirre
I have configured a lab for RA VPNs with a ASA5510 software version 8.2 and VPN Client 5 using digital certificates with Microsoft CA on a Windows 2003 server. I did the configuration based on this document from Cisco website:
http://www.cisco.com/en/US/partner/products/ps6120/products_configuration_example09186a0080930f21.shtml
Now the vpn works just fine, but now I need to configure different tunnel-groups so I can provide different services to different users. The problem I have now is that I don't know how to configure it so the certificate matches the tunnel-group name. If i do a debug crypto isakmp on ASA I get this error messages:
%ASA-7-713906: IP = 165.98.139.12, Trying to find group via OU...
%ASA-3-713020: IP = 165.98.139.12, No Group found by matching OU(s) from ID payload:   Unknown
%ASA-7-713906: IP = 165.98.139.12, Trying to find group via IKE ID...
%ASA-7-713906: IP = 165.98.139.12, Trying to find group via IP ADDR...
%ASA-7-713906: IP = 165.98.139.12, Trying to find group via default group...
%ASA-7-713906: IP = 165.98.139.12, Connection landed on tunnel_group DefaultRAGroup
So basically when using certificates I always connect the RA VPN only with the default group DefaultRAGroup. Do I need to use a different web enrollment template for certificate request instead of the user template??? How can I define the OU on the User certificate so it matches the tunnel-group???
Please help me!!!!
Fernando Aguirre
Jennifer Halim
You can use the certificate group map feature to map it to a specific group.
Here is the configuration guide for your reference:
http://www.cisco.com/en/US/partner/docs/security/asa/asa82/configuration/guide/ike.html#wp1053978
And here is the command reference for "crypto ca certificate map":
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/c5.html#wp2186685
Hope that helps.
Jennifer Halim
Hope that helps.
Thanks, the information you sent me was very helpful. I have the tunnel group mapping working with certificates now.
One of the links is bronken.
I found new and very usefull info, Posted by Petr Lapukhov:
http://blog.ine.com/tag/tunnel-group/
1)The rules are configured using the command
crypto ca certificate map [] .
2) Enable the mapping rules using the command
tunnel-group-map enable rules.
3) Configure certificate map to tunnel-group mapping using the global commands
tunnel-group-map []
The rules are configured using the command crypto ca certificate map [] .
My Conf:
crypto ca certificate map CertMap 10
issuer-name attr cn co RT_CA01
subject-name co ARRT01
tunnel-group-map CertMap 10 vpnBranches
More info on Cisco ASA 5500 Series Configuration Guide using the CLI
search for "Creating a Certificate Group Matching Rule and Policy"
Hello and sorry to bring this old topic up again :-)
I'm aware of the certificate group map feature but in our environment we are not able to use it, as the customer wants to use the option of "group-delimiter #" to make users fall into a special tunnel-group in some circumstances.
I have heard, that you could name the tunnel-group the same as the OU-Field from the certificate to make users fall into that tunnel-group, is this correct and is there any documentation from cisco about that feature?
I'm relatively new to ASA and what I have learned is, to use certificate group map :-)
Thank you guys in advice.
Best regards,
Thomas
