SA520 SSL VPN WAN IP Address
Apr 17th, 2010
I've an SA520 with WAN IP Address connected to private LAN of ADSL Router.
ADSL Router has a public ip address (like 84.73.x.y).
ADSL Router routes all traffic to SA520 WAN Port.
I've configured SSLVPN on SA520. The server portal URL is automatically setted to and i can't change it.
Users access SSLVPN portal on URL http://84.73.x.y/portal/sslvpn (i.e. the pubblic ip address of ADSL Router). They can access to login page but they can't permorfe login.
I found that after an user click login button on SSL portal login page, browser try to request a page pointing to wrong url (i.e. the address of SA520 on network between SA520 e ADSL Router).
Any suggest?
biraja Sat, 04/17/2010 - 14:43
Hi Brapao,
I'll try it out myself and get back to you if there is any solution for this scenario.
Is IP-Aliasing supported on the ADSL router? If so, you can map a public address to the local address and directly connect to the SA500 router using public IP.
Thanks and Regards,
a.portesi Sun, 04/18/2010 - 23:45
Hi Biraja, thnaks for your response.
Unfortunately, Router doesn't support ip aliasing!!!
We will schedule a firmware upgrade!
Related Content
