IPSec VPN Remote-Access and TCP MSS issue
Apr 17th, 2010
I'd like your advice about an issue with IPSec and TCP MSS.
I have the following architecture in production
Cisco VPN Client------------------PacketShaper---------------------------------VPN 3000-------------------LAN
TCP MSS 1300                   TCP Window Sizing                              TCP MSS 1280
                                         equals to TCP MSS=1460
The Cisco VPN Client can connect to the VPN 3000 (IPSec VPN Remote-Access connection) and send/receive traffic.
I decided to change the VPN 3000 by a Cisco ASA 5510.
On the Cisco ASA, I entered the same command "sysopt connection tcpmss 1280" but it failed.
We can see the IKE Phase 1 & 2 established (IPSec tunnel OK). But no traffic possible and after 2minutes, a timeout occurs.
So, on the PacketShaped, we decided to disabled the TCP Window Sizing on the PacketShaper. Success.
BUT, why such a difference between a VPN 3000 and ASA with IPSec tunnel ????
Have you ever met something like that ?
I don't want to change the PackerShaper configuratio, because the TCP Window Sizing is for all connections.
On Cisco ASA, I can't find any solution.
Here're my tests:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
VPN 3000
TCP Window Sizing enabled
TCP MSS = 1460
Command :
TCP MSS=1460
no command (so TCP MSS=1380 by default)
TCP Window Size enabled
TCP MSS=1460
Command :
TCP Window Size disabled
Thanks for any answer.
sverbeek-cap Mon, 07/12/2010 - 01:50
Hi Leon,
We experience exactly the same issue here when replacing a VPN 3000 with an ASA 5540.
Did you eventually find a solution?
Jason Gervia Mon, 07/12/2010 - 06:53
What kind of VPN are you using?  The VPN client connection by default is either ESP protocol 50 or UDP encapsulated ESP on port 4500, so a MSS adjustments on encrypted packets (that aren't even TCP) won't have an effect.
Are you using IPSEC over TCP?
sverbeek-cap Tue, 07/13/2010 - 00:28
Hi Jason,
Yes indeed, we are using IPSEC over TCP port 443, forgot to mention that.
