how to put a port to trunk mode using SNMP on Catalyst 2970 and 3759G switch
Apr 17th, 2010
Has anybody figured out how to change the mode of a port on Catalyst 2970 and 3750G
switch from access to trunk using SNMP?
On Catalyst 3500XL switch, when I did an SNMP walk on vlanTrunkPortRowStatus mib
variable in CISCO-VTP-MIB, I only gathered the trunk port information and this result is
correct.I can put a port to trunk mode by assigning 'createAndGo' value to vlanTrunkPortRowStatus
mib vatiable.
But unfortunately, on Catalyst 2970 and 3750G, I gathered all access port and trunk port information
when I did so. Using this mib, I can't realize my goal.
Is there another way of accomplishing this using SNMP?
Zhou
Joe Clarke Sat, 04/17/2010 - 09:33
The CISCO-VTP-MIB is the way to go on 2970 and 3750 switches.  All access ports will have a vlanTrunkPortDynamicStatus value of notTrunking(2) where as all trunk ports will have the value of trunking(1).  To change an access port to trunk port, do:
vlanTrunkPortEncapsulationType.IFINDEX -> 4 (for dot1q encap)
vlanTrunkPortDynamicState.IFINDEX -> 1
That's the simplest way of doing things.  You can also set things like native VLAN and allowed VLANs in the same vlanTrunkPortTable.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
