Transceiver Report in Ciscoworks?
Answered Question
Apr 17th, 2010
Is there a transceiver only report available in Ciscoworks? I was trying to do this in the Custom Reports in LMS 3.2, RME but I didn't see a way how other than to generate a detailed device report.
If there isn't, are there plans to implement one in LMS 4.0?
-David
Correct Answer by Joe Clarke about 7 years 1 month ago
No, this cannot be done yet.  There is an enhancement open to get port serial numbers (e.g. for SFPs, GBICs, etc.).  That bug ID is CSCsz48654.  There is also another bug open to pull all RME DDR attributes into custom reports (CSCsj78780).  RME 4.0 will have some of this, but serial numbers right now are not available.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Overall Rating: 5 (1 ratings)
david.fernandes... Sat, 04/17/2010 - 10:01
sfp type, description, and serial number and the device port it is
located on.
On Apr 17, 2010, at 12:36 PM, jclarke
Correct Answer
Joe Clarke Sat, 04/17/2010 - 13:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Adrian Lazar Wed, 01/12/2011 - 00:29
Hi Joseph,
We have installed an evaluation version of LMS 4.0 and I was particularly looking for this feature - obtaining SFP serial numbers via a report.
Can you please confirm if this is included or not in LMS 4.0 ? I have looked for it in all harware reports and detailed device reports but no luck so far.
Adrian
Joe Clarke Wed, 01/12/2011 - 22:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, this is not in LMS 4.0.  I'm talking with the product team to try and get this added to the next release.
Adrian Lazar Thu, 01/13/2011 - 00:13
Hi Joseph,
Thanks for the reply.
Do you know of any other way to obtain the S/N of swiches and all of their components (including SFPs ), that we could use ?
Adrian
Adrian Lazar Thu, 01/13/2011 - 00:52
Can you please be more specific? This is about quite a few devices,200-300 that we need to poll for serial numbers and get the information in an easy to read and process format. Do you know any SNMP tool that can do that?
Adrian
Dan-Ciprian Cicioiu Thu, 01/13/2011 - 01:09
  • Gold, 750 points or more
You can write a script , that could query each device, based on the type of the chassis you can query for specific mib to get , S/N of the equipment and also other modules inserted ( spf , gbic etc. )
Dan
Joe Clarke Thu, 01/13/2011 - 22:46
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
A script to walk the entPhysicalTable looking at the entPhysicalSerialNum object would be the way to do this for such devices.  I do not know of any existing scripts that do this down to the port level.
CARL VON HASSEL Fri, 11/02/2012 - 06:02
The only way I know is to run a Netconfig job. Then run show inventory (enable). It's not to clean but it works.
