PAT with DHCP on Firewall
Marcos Hernandez Sun, 04/18/2010 - 07:57
  • Blue, 1500 points or more
Do you mean port forwarding? If so, you can still do this. I would recommend that you use DDNS, so when accessing your application from the outside you can just point it to a named destination, rather than an IP which wuld change.
If your mean NAT/PAT from the inside out, that should work too.
Marcos
