Question about PPP multilink(with Debug message)
Answered Question
Apr 18th, 2010
Hi,friends,I want use PPP multilink binding 2 E1 interface,My device is cisco 7609 + SIP-400 + SPA-8XCHT1/E1, other side is H3C MSR 5060. After the configuration,I found the 2 E1 interfaces are UP UP , but the interface multilink is Down  Down?
Here is "show interface multilink 1" command execute,I found the LCP is "Initial":
cisco#show int multilink 1
Multilink1 is down, line protocol is down
  Hardware is multilink group interface
  Internet address is 1.1.1.1/8
  MTU 1500 bytes, BW 4096 Kbit, DLY 20000 usec,
     reliability 230/255, txload 1/255, rxload 1/255
  Encapsulation PPP, LCP Initial, multilink Open, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 2 seconds on reset
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 01:31:55
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     298 packets input, 14168 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     13144 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     83 packets output, 1954 bytes, 0 underruns
     0 output errors, 0 collisions, 11 interface resets
     0 carrier transitions
My configuration is:
interface Multilink1
no ip address
ppp multilink
ppp multilink group 1
no cdp enable
interface Serial4/0/1:0
no ip address
encapsulation ppp
ppp multilink
interface Serial4/0/2:0
no ip address
encapsulation ppp
ppp multilink
Here is the Debug Message,with the command "debug ppp negotiation":
cisco(config-if)#
*Apr 16 01:26:45.319: Se4/0/1:0 PPP DISC: PPP Renegotiating
*Apr 16 01:26:45.319: Se4/0/1:0 LCP: Event[DOWN] State[Open to Starting]
*Apr 16 01:26:45.319: Se4/0/1:0 PPP: Phase is DOWN
*Apr 16 01:26:45.319: Se4/0/2:0 PPP DISC: PPP Renegotiating
*Apr 16 01:26:45.319: Se4/0/2:0 LCP: Event[DOWN] State[Open to Starting]
*Apr 16 01:26:45.319: Se4/0/2:0 PPP: Phase is DOWN
*Apr 16 01:26:45.327: PPP: Alloc Context [46B5E1E8]
*Apr 16 01:26:45.327: ppp86 PPP: Phase is ESTABLISHING
cisco(config-if)# Alloc Context [46B5EC08]
*Apr 16 01:26:45.327: ppp87 PPP: Phase is ESTABLISHING
*Apr 16 01:26:45.327: Se4/0/1:0 PPP: Using default call direction
*Apr 16 01:26:45.327: Se4/0/1:0 PPP: Treating connection as a dedicated line
*Apr 16 01:26:45.327: Se4/0/1:0 PPP: Session handle[86000065] Session id[86]
*Apr 16 01:26:45.327: Se4/0/1:0 LCP: Event[OPEN] State[Initial to Starting]
*Apr 16 01:26:45.327: Se4/0/1:0 LCP: O CONFREQ [Starting] id 1 len 24
*Apr 16 01:26:45.327: Se4/0/1:0 LCP:    MagicNumber 0x1B5
cisco(config-if)#CCD6A (0x05061B5CCD6A)
*Apr 16 01:26:45.327: Se4/0/1:0 LCP:    ACFC (0x0802)
*Apr 16 01:26:45.327: Se4/0/1:0 LCP:    MRRU 1500 (0x110405DC)
*Apr 16 01:26:45.327: Se4/0/1:0 LCP:    EndpointDisc 1 cisco (0x130801636973636F)
*Apr 16 01:26:45.327: Se4/0/1:0 LCP: Event[UP] State[Starting to REQsent]
*Apr 16 01:26:45.327: Se4/0/2:0 PPP: Using default call direction
*Apr 16 01:26:45.327: Se4/0/2:0 PPP: Treating connection as a dedicated line
*Apr 16 01:26:45.327: Se4/0/2:0 PPP: Session handle[38000066] Ses
cisco(config-if)#sion id[87]
*Apr 16 01:26:45.327: Se4/0/2:0 LCP: Event[OPEN] State[Initial to Starting]
*Apr 16 01:26:45.327: Se4/0/2:0 LCP: O CONFREQ [Starting] id 1 len 24
*Apr 16 01:26:45.327: Se4/0/2:0 LCP:    MagicNumber 0x1B5CCD6B (0x05061B5CCD6B)
*Apr 16 01:26:45.327: Se4/0/2:0 LCP:    ACFC (0x0802)
*Apr 16 01:26:45.327: Se4/0/2:0 LCP:    MRRU 1500 (0x110405DC)
*Apr 16 01:26:45.327: Se4/0/2:0 LCP:    EndpointDisc 1 cisco (0x130801636973636F)
*Apr 16 01:26:45.327: Se4/0/2:0 LCP: Event[UP] State[Starting to RE
cisco(config-if)#Qsent]
*Apr 16 01:26:45.359: Se4/0/1:0 LCP: I CONFREQ [REQsent] id 204 len 28
*Apr 16 01:26:45.359: Se4/0/1:0 LCP:    MRU 1500 (0x010405DC)
*Apr 16 01:26:45.359: Se4/0/1:0 LCP:    MagicNumber 0x004437E4 (0x0506004437E4)
*Apr 16 01:26:45.359: Se4/0/1:0 LCP:    ACFC (0x0802)
*Apr 16 01:26:45.359: Se4/0/1:0 LCP:    MRRU 1500 (0x110405DC)
*Apr 16 01:26:45.359: Se4/0/1:0 LCP:    MultilinkShortSeq (0x1202)
*Apr 16 01:26:45.359: Se4/0/1:0 LCP:    EndpointDisc 1 aaa (0x130601616161)
cisco(config-if)#e4/0/1:0 LCP: O CONFREJ [REQsent] id 204 len 6
*Apr 16 01:26:45.359: Se4/0/1:0 LCP: Event[Receive ConfReq-] State[REQsent to REQsent]
*Apr 16 01:26:45.359: Se4/0/1:0 LCP: I CONFACK [REQsent] id 1 len 24
*Apr 16 01:26:45.359: Se4/0/1:0 LCP:    MagicNumber 0x1B5CCD6A (0x05061B5CCD6A)
cisco(config-if)#   EndpointDisc 1 cisco (0x130801636973636F)
*Apr 16 01:26:45.359: Se4/0/1:0 LCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
*Apr 16 01:26:45.359: Se4/0/2:0 LCP: I CONFREQ [REQsent] id 202 len 26
*Apr 16 01:26:45.359: Se4/0/2:0 LCP:    MRU 1500 (0x010405DC)
*Apr 16 01:26:45.359: Se4/0/2:0 LCP:    MagicNumber 0x0043F92B (0x05060043F92B)
*Apr 16 01:26:45.363: Se4/0/2:0 LCP:    MRRU 1500 (0x110405DC)
*Apr 16 01:26:45.363: Se4/0/2:0 LCP:    MultilinkShortSeq (0x1202)
cisco(config-if)#0 LCP:    EndpointDisc 1 aaa (0x130601616161)
*Apr 16 01:26:45.363: Se4/0/2:0 LCP: O CONFREJ [REQsent] id 202 len 6
*Apr 16 01:26:45.363: Se4/0/2:0 LCP: Event[Receive ConfReq-] State[REQsent to REQsent]
*Apr 16 01:26:45.363: Se4/0/2:0 LCP: I CONFACK [REQsent] id 1 len 24
*Apr 16 01:26:45.363: Se4/0/2:0 LCP:    MagicNumber 0x1B5CCD6B (0x05061B5CCD6B)
*Apr 16 01:26:45.363: Se4/0/2:0 LCP:    ACFC (0x0802)
cisco(config-if)# LCP:    MRRU 1500 (0x110405DC)
*Apr 16 01:26:45.363: Se4/0/2:0 LCP:    EndpointDisc 1 cisco (0x130801636973636F)
*Apr 16 01:26:45.363: Se4/0/2:0 LCP: Event[Receive ConfAck] State[REQsent to ACKrcvd]
*Apr 16 01:26:45.391: Se4/0/1:0 LCP: I CONFREQ [ACKrcvd] id 205 len 26
*Apr 16 01:26:45.391: Se4/0/1:0 LCP:    MRU 1500 (0x010405DC)
*Apr 16 01:26:45.391: Se4/0/1:0 LCP:    MagicNumber 0x0043EFCA (0x05060043EFCA)
*Apr 16 01:26:45.391: Se4/0/1:0 LCP:    ACFC (0x0802)
cisco(config-if)#   MRRU 1500 (0x110405DC)
*Apr 16 01:26:45.391: Se4/0/1:0 LCP:    EndpointDisc 1 aaa (0x130601616161)
*Apr 16 01:26:45.391: Se4/0/1:0 LCP: O CONFACK [ACKrcvd] id 205 len 26
*Apr 16 01:26:45.391: Se4/0/1:0 LCP:    MRRU 1500 (0x110405DC)
cisco(config-if)#61)
*Apr 16 01:26:45.391: Se4/0/1:0 LCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
*Apr 16 01:26:45.395: Se4/0/2:0 LCP: I CONFREQ [ACKrcvd] id 203 len 24
*Apr 16 01:26:45.395: Se4/0/2:0 LCP:    MRU 1500 (0x010405DC)
*Apr 16 01:26:45.395: Se4/0/2:0 LCP:    MagicNumber 0x0043D1C6 (0x05060043D1C6)
*Apr 16 01:26:45.395: Se4/0/2:0 LCP:    MRRU 1500 (0x110405DC)
*Apr 16 01:26:45.395: Se4/0/2:0 LCP:    EndpointDisc 1 aaa (0x130601616161)
*Apr 16 01:26:45.395: Se4/0/2:0 LCP: O CONFACK [ACKrcvd] id 203
cisco(config-if)#len 24
*Apr 16 01:26:45.395: Se4/0/2:0 LCP: Event[Receive ConfReq+] State[ACKrcvd to Open]
*Apr 16 01:26:45.415: Se4/0/1:0 PPP: Phase is FORWARDING, Attempting Forward
*Apr 16 01:26:45.415: Se4/0/1:0 LCP: State is Open
*Ap
cisco(config-if)#r 16 01:26:45.415: Se4/0/2:0 PPP: Phase is FORWARDING, Attempting Forward
*Apr 16 01:26:45.415: Se4/0/2:0 LCP: State is Open
*Apr 16 01:26:45.415: Se4/0/1:0 PPP: Phase is ESTABLISHING, Finish LCP
*Apr 16 01:26:45.415: Se4/0/1:0 PPP: Phase is VIRTUALIZED
*Apr 16 01:26:45.415: Se4/0/2:0 PPP: Phase is ESTABLISHING, Finish LCP
*Apr 16 01:26:45.415: Se4/0/2:0 PPP: Phase is VIRTUALIZED
*Apr 16 01:26:45.415: PPP: Alloc Context [46B5E398]
*Apr 16 01:26:45.415: ppp88 PPP: Phase is ESTABLISHING
*Apr 16 01:26
cisco(config-if)#:45.419: Mu1 MLP: Added first link Se4/0/1:0 to bundle aaa
*Apr 16 01:26:45.419: Mu1 MLP: Added link Se4/0/2:0 to bundle aaa
*Apr 16 01:26:45.423: Se4/0/1:0 PPP: Queue IPCP code[1] id[0]
*Apr 16 01:26:45.543: Se4/0/1:0 PPP: Free Context [46B5E8A8]
*Apr 16 01:26:45.543: Se4/0/2:0 PPP: Free Context [46B5EA58]
*Apr 16 01:26:48.415: Se4/0/1:0 PPP: Update queued IPCP code[1] id[1]
*Apr 16 01:26:51.415: Se4/0/2:0 PPP: Queue IPCP code[1] id[2]
*Apr 16 01:26:54.415: Se4/0/1:0 PPP: Update queued IPCP code[1]
cisco(config-if)# id[3]
*Apr 16 01:26:57.415: Se4/0/2:0 PPP: Update queued IPCP code[1] id[4]
cisco(config-if)#
Apr 16 01:50:00.915: Se4/0/1:0 PPP: Update queued IPCP code[1] id[3]
cisco#
*Apr 16 01:50:03.915: Se4/0/2:0 PPP: Update queued IPCP code[1] id[4]
cisco#
*Apr 16 01:50:36.915: Se4/0/1:0 PPP: Update queued IPCP code[1] id[5]
cisco#
*Apr 16 01:50:39.915: Se4/0/2:0 PPP: Update queued IPCP code[1] id[6]
cisco#
*Apr 16 01:50:42.915: Se4/0/1:0 PPP: Update queued IPCP code[1] id[7]
cisco#
*Apr 16 01:50:45.915: Se4/0/2:0 PPP: Update queued IPCP code[1] id[8]
cisco#
*Apr 16 01:50:48.915: Se4/0/1:0 PPP: Update queued IPCP code[1] id[9]
And the H3C router's Mpgroup interface is UP, Can you help me? Thanks.
Correct Answer by Richard Burts about 6 years 8 months ago
Hou
I am glad to know that you have resolved the problem. Thank you for posting back and indicating that it was solved and what you did to solve it. It makes the forum more helpful when people can read about an issue and can also read what was the successful solution to the issue.
Rick
Overall Rating: 5 (1 ratings)
Reza Sharifi Sun, 04/18/2010 - 08:49
Hi Hou,
have you configured the time slots for each E1 interface?
controller E1 4/0/1 and 4/0/2
framing NO-CRC4
channel-group 1 timeslots 1-31
Reza
Giuseppe Larosa Sun, 04/18/2010 - 09:19
Hello Hou,
from the following lines taken from your debug:
the cisco router receives a Configuration Request
that describes the parameters for the PPP multilink connection but it doesn't like it and sends back a configuration  reject
I = input received from neighbor
O = output sent to neighbor
on the  other side have you set a name for the bundle or any other additional parameter?
what is the output of
debug ppp multilink?
also useful is
sh ppp multilink
another note:
if you want to negotiate an IP address with IPCP you should use ip address negotiated in multilink interface instead of no ip address
Also if it is a C7600 you need to use two serial interfaces taken from the same SPA or PA but you are fine you are using two interfaces on same SPA.
Hope to help
Giuseppe
houbochen Sun, 04/18/2010 - 23:50
Dear giuslar:
Thanks for your answer,the debug message is out of the command "show ppp negotiate".
My router is 7609,and I use 2 E1 interface on the same SIP & SPA,there is nothing wrong. So I decide to check the other side's configuration.
houbochen Mon, 04/19/2010 - 01:07
I can't get the answer.
My configuration on the remote site is below ,the router is H3C MSR50 60:
display current-configuration
version 5.20, Release 1809P01, Basic
sysname R5060
interface Serial10/1
fe1 unframed
link-protocol ppp
ppp mp Mp-group 1
interface Serial10/2
fe1 unframed
link-protocol ppp
ppp mp Mp-group 1
interface Mp-group1
ip address 1.1.1.2 255.255.255.0
I tried debug the remote device,I found the LCP is Open first,then it changes Request,I don't know why!
system-view
*Apr 19 06:53:16:384 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/0 Output LCP(c021) Pkt, Len 12
      State opened, code EchoRequest(09), id 4e, len 8
      Magic Number 0000e56d
*Apr 19 06:53:16:415 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/0 Input  LCP(c021) Pkt, Len 12
      State opened, code EchoReply(0a), id 4e, len 8
      Magic Number 1b123f27
  PPP Event:
      Serial10/0 LCP RXR(Receive EchoRequest/EchoReply/DiscardRequest)  Event
      state opened
*Apr 19 06:53:17:680 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/0 Input  LCP(c021) Pkt, Len 16
      State opened, code EchoRequest(09), id 4e, len 12
      Magic Number 1b123f270000e56d
  PPP Event:
      state opened
*Apr 19 06:53:17:681 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/0 Output LCP(c021) Pkt, Len 16
      State opened, code EchoReply(0a), id 4e, len 12
      Magic Number 0000e56d0000e56d
*Apr 19 06:53:21:254 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/2 Output LCP(c021) Pkt, Len 12
      State opened, code EchoRequest(09), id 44, len 8
      Magic Number 000bf5e4
*Apr 19 06:53:21:264 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/1 Output LCP(c021) Pkt, Len 12
      State opened, code EchoRequest(09), id 41, len 8
      Magic Number 000c07ec
*Apr 19 06:53:21:285 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/2 Input  LCP(c021) Pkt, Len 12
      State opened, code EchoReply(0a), id 44, len 8
      Magic Number 1b1d8fa1
  PPP Event:
      Serial10/2 LCP RXR(Receive EchoRequest/EchoReply/DiscardRequest)  Event
      state opened
*Apr 19 06:53:21:295 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/1 Input  LCP(c021) Pkt, Len 12
      State opened, code EchoReply(0a), id 41, len 8
      Magic Number 1b1d8fa2
  PPP Event:
      Serial10/1 LCP RXR(Receive EchoRequest/EchoReply/DiscardRequest)  Event
      state opened
*Apr 19 06:53:21:360 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/2 Input  LCP(c021) Pkt, Len 16
      State opened, code EchoRequest(09), id 4, len 12
      Magic Number 1b1d8fa1000bf5e4
*Apr 19 06:53:21:361 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Event:
      state opened
  PPP Packet:
      Serial10/2 Output LCP(c021) Pkt, Len 16
      State opened, code EchoReply(0a), id 4, len 12
      Magic Number 000bf5e4000bf5e4
*Apr 19 06:53:21:392 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/1 Input  LCP(c021) Pkt, Len 16
      Magic Number 1b1d8fa2000c07ec
  PPP Event:
      state opened
  PPP Packet:
      Serial10/1 Output LCP(c021) Pkt, Len 16
      Magic Number 000c07ec000c07ec
*Apr 19 06:53:26:384 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      State opened, code EchoRequest(09), id 4f, len 8
*Apr 19 06:53:26:415 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      State opened, code EchoReply(0a), id 4f, len 8
  PPP Event:
      state opened
*Apr 19 06:53:27:697 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      State opened, code EchoRequest(09), id 4f, len 12
  PPP Event:
      state opened
  PPP Packet:
      State opened, code EchoReply(0a), id 4f, len 12
*Apr 19 06:53:29:684 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Event:
      Serial10/3 LCP Close  Event
      state closed
  PPP Event:
      Serial10/3 LCP Open  Event
      state closed
  PPP State Change:
      Serial10/3 LCP : closed --> reqsent
  PPP Packet:
      Serial10/3 Output LCP(c021) Pkt, Len 18
      State reqsent, code ConfReq(01), id 16, len 14
      MRU(1), len 4, val 05dc
      MagicNumber(5), len 6, val 000cbc49
*Apr 19 06:53:29:738 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/3 Input  LCP(c021) Pkt, Len 18
  PPP Event:
      Serial10/3 LCP RCR-(Receive Config Bad Request)  Event
      state reqsent
  PPP Packet:
      Serial10/3 Output LCP(c021) Pkt, Len 14
      State reqsent, code ConfNak(03), id 16, len 10
      MagicNumber(5), len 6, val 000ce30a
*Apr 19 06:53:29:791 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      Serial10/3 Input  LCP(c021) Pkt, Len 14
  PPP Event:
      Serial10/3 LCP RCN(Receive Config Nak/Reject)  Event
      state reqsent
*Apr 19 06:53:29:792 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
      State reqsent, code ConfReq(01), id 17, len 14
      MagicNumber(5), len 6, val 000ccaa7
*Apr 19 06:53:29:845 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
  PPP Event:
      state reqsent
  PPP Packet:
      State reqsent, code ConfNak(03), id 17, len 10
      MagicNumber(5), len 6, val 000cae47
*Apr 19 06:53:29:899 2010 DLHSQ_R5060 PPP/7/debug2:
  PPP Packet:
  PPP Event:
      state reqsent
houbochen Sat, 05/15/2010 - 02:16
It's a software bug,I update IOS with 122-33.SRD4,everything is Ok,thanks everyone.
Correct Answer
Richard Burts Sat, 05/15/2010 - 12:46
Hou
Rick
