04-18-2010 08:37 AM - last edited on 03-25-2019 07:58 PM by ciscomoderator
Hi All,
I have configured extension mobility, the users can loggin but the logout option doesnot work. Instead when you press the Services Button it will be showing go to this URL to set up speed dail.
Any idea on how to fix this issue.
Solved! Go to Solution.
04-18-2010 11:01 AM
Hi there,
Here is a very similar thread
https://supportforums.cisco.com/message/1181614#1181614
Cheers!
Rob
04-18-2010 11:45 AM
You've subscribed the phone to the EM service.
When you log in, the phone properties (lines, config, and services) applied to the phone are the ones from the Device Profile you have logged in with. As you haven't subscribed the Device Profile to any services, you get the default prompt you have seen.
So what you need to do is ensure that you subscribe all your Device Profiles to the EM service as well.
Aaron
04-18-2010 11:01 AM
Hi there,
Cheers!
Rob
04-18-2010 11:45 AM
Aaron
04-22-2010 05:20 AM
thanks man, all is fine and working.
your suggestion is the way out.
regards,
dafe oroghi
