CUCM7 admin prompt?
Answered Question
Apr 18th, 2010
Hello all,
I installed CUCM7 in Vmware server. It loads to a login prompt, which I type in my login and password.  Then I'm successfully at the "admin" prompt.  So how do I get to the Call Manager 7 GUI from here?  Everything I find simply states to go to https://<ip address>/ccmadmin/, but this isn't working. I assume because the only IE interface I have is not in the VMware, but on my PC.  Can anyone help me out here?
Thank you greatly in advance,
Eric
Correct Answer by Aaron Harrison about 7 years 1 month ago
You need to have IP reachability from a client device (i.e your PC) to the CCM server. You can only configure CCM from a remote web browser session.
So if you are using VMWare, either:
1) Give the server an address on your local VLAN, and use a bridged LAN interface in the VM.
2) Give the server an address in the 'host only' subnet, and set the 'host only' network option.
3) Set the server to 'host only' networking, and then change the address on the 'host only' NIC in your VMWare host PC to have an address on the same IP subnet as the CCM server.
Really Option 1 above is the only practical one if you have IP phones or other devices not on your VM host that you want to use with the CCM server.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Sun, 04/18/2010 - 12:51
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Aaron Harrison Sun, 04/18/2010 - 13:28
No problem
