How to set up remote VPN client to work remotely but appear as they log in from the main local office ?
Apr 18th, 2010
Question is: For our business model, if we want to set up is a simple way for remote users to log in to our VPN network working on temporary projects to connect to certain network resources remotely but appear to be working from the main offices ?
Please feel free to recommend any proper way to implement it. Any input would be appreciated.
QN
Jennifer Halim Sun, 04/18/2010 - 16:47
Just configure either ipsec remote vpn client or anyconnect/ssl remote vpn client to your main office. You can configure different policy for each different projects, and remove access once the project is completed.
What VPN device do you have at your main site?
quocnguyen0607 Mon, 04/19/2010 - 20:47
Thanks for your quick response. I'd like to spec out the
most efficiency equipments to serve the work within the budget.
Would you might to give some idea for it ? Just basic setup for VPN networks.
This is my first time to build the VPN network.
your help would be greatful appreciated.
QN
