CUE script to allow PSTN calls
moin.tirmizi
Hi All,
I am using an AA script in CUE and have a requirement when user press "1"  in the AA. He needs to be transferred to an external number(Mobile number).
The "Call Redirect" function allows calls to be transferred to internal extension only and not to external PSTN phone numbers.
Can some one send me the sample script to achieve external transfer or  show me the steps? I have attached the script I am using for your refrence. And I use "9" prefix to get an outside line.
Following would give you an idea on the script flow.
1.1        Script Content
Start
/* External_Transfer.aef */
Accept (contact: --Triggering Contact--)
        Emergency Contact
                Call Redirect (contact: --Triggering Contact--, extension: EmergencyNumber)
                        Successful
                        Busy
                        Invalid
                        Unsuccessful
                End
End
1.2        Variables
Name
Type
Value
EmergencyNumber
java.lang.String
90408123123
Many thanks,
Moin
paolo bevilacqua
"call redirect" allow transfers to any number.
paolo bevilacqua
Yes you ar right mate.
Only one of my router is not forwarding the call, as I dont see any call origination in CCAPI  debugs I suspect its CUE not sending the call. I tried on couple of other site routers and they both allowed external transfer.
You could always have it transfer to a DN which has CFA set to the external number.
You are right Mark,
That's the work around I was using before, but as I mentioned its just one router no transferring calls. I'll check to see why as it should. Thanks ofr your advice.
