when using vtp pruning, why vtp transparent mode can cause network instability ?
Answered Question
Apr 18th, 2010
where does vtp pruning message encapsulated ?  Is it support by vtp transparent mode ?
Correct Answer by Jon Marshall about 7 years 3 months ago
VTP pruning is not supported with VTP transparent. A VTP transparent switch will still pass VTP updates but it is recommended by Cisco that if you are running some of the switches in VTP transparent mode you should disable VTP pruning in your network.
Do't forget that you can always use the "switchport trunk allowed vlan ..." command to specifically control which vlans are allowed across trunk links.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 04/19/2010 - 00:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
