IPS automatic update to E4 engine
Apr 19th, 2010
Is there a way for the IPS to automatically download the E4 engine through an FTP server like the signature auto update?
I need the answer the the below scnearios
1- upgrade from 7.0(2)E3 to 7.0(2)E4
1- upgrade from 7.0(1)E3 to 7.0(2)E4 -> In this case the whole SP should be downloaded, I doubt this can be done automatically but just in case there is a new way to do it???
Jennifer Halim Mon, 04/19/2010 - 00:10
  • Cisco Employee,
- Upgrade from 7.0(2)E3 to 7.0(2)E4 can be done automatically through the auto-update from cisco.com. When you perform the signature auto update, it will automatically update the engine to E4.
- Upgrade from 7.0(1)E3 to 7.0(2)E4 needs to be done as per normal upgrade process, ie: download the upgrade package "IPS-K9-7.0-2-E4.pkg", and update the sensor.
Hope that helps.
k.abillama Mon, 04/19/2010 - 00:13
Yes sure it helps, but just to make sure, if it can be done through cisco.com then it can be also done through a hosted FTP server
Actually we are hosting an FTP server on which we are regulary updating the signatures set, we were thinking of downloading the E4 engine as well but I guess we'll have to do it for each Service Pack
Jennifer Halim Mon, 04/19/2010 - 00:19
  • Cisco Employee,
If you are using FTP server, and if you are already running the latest within that Service Pack, for example: 7.0.2(E3), then you just need to update the engine using this file:  IPS-engine-E4-req-7.0-2.pkg
Jennifer Halim Mon, 04/19/2010 - 00:53
  • Cisco Employee,
Great to hear.
Please always mark question as answered and rate useful post. Thanks.
