UCM6.1 Route Groups and SIP Trunks
Apr 19th, 2010
I have the following case:
I need to configure a route group that contain 3 SIP Trunks, however in the Rout Group configuration page the SIP Trunks are not listed under the availabe devices. I'm using UCM
However, in UCM 7.1 I do have the SIP trunks listed under the available devices for the Rout Group configuration page!
Dose any one have this limitations also?
Aaron Harrison Mon, 04/19/2010 - 00:23
If you have a Route Pattern pointed directly at the Route Group, it will be hidden - remove the RP, and you'll be able to add it to a route group.
Please rate helpful posts...
