Not able to save configuration in sim question BCMSN(642-812)
Apr 19th, 2010
On 17thApr 2010(2 days back) my friend experienced an issue regarding not able to save the configuration he did in the simulator question...
He tried all the commands like
copy running-config startup-config
copy run start
wr
write mem
but none worked....
The only thing he was left with was to proceed  to next question without saving his config and wasting lot of time.
Pls care to tell me is there any issue in sim itself or some other command needs to used.
Fast reply would be highly appretiated as i also have to appear for the same exam tomorrow i.e; 20th Apr 2010
Warm Regards,
Shahid
Marko Leopold Mon, 04/19/2010 - 00:38
Well i was trying the same in BSCI sim and it did not worked either. So i guess, it's not a bug it's a feature. After trying it several times i refused clicked Next.
Giuseppe Larosa Mon, 04/19/2010 - 04:50
  • Hall of Fame,
    Founding Member
Hello Shahid,
in the exam context you should do only what is required: if saving the configuration is not explicitly requested you just have to end configuration with the appropriate command ( just an enter keystroke or end)
I strongly suggest to take the time to use the tutorial and follow the instructions.
The time for the tutorial is not taken from the exam time, so it is wise to attend to the tutorial.
It is not real world, and you are not dealing with a real router, it is just a SW that presents you a prompt and collect your input and it will compare it with the expected answers.
Hope to help
Giuseppe
