Connecting POTS across the network
Apr 19th, 2010
Hi all
Is it possible to connect POTS phones to a switch across the network using ATA,s? Or is it a case of having to connect point to point over the structured cabling using balons back to FXS port completely by passing the network?
Simon
paolo bevilacqua Mon, 04/19/2010 - 01:57
  • Hall of Fame,
    Founding Member
In other words, what problem are you traying to solve ?
simonmossman Mon, 04/19/2010 - 04:22
I have no structured cabling / RJ45 outlets at the required remote locations to patch back to. However they have spare switch ports going back to the comms room where the POTS lines are presented
paolo bevilacqua Mon, 04/19/2010 - 06:48
  • Hall of Fame,
    Founding Member
You can use these for any purpose. No baluns are needed. You can also find pre-made splitters.
simonmossman Tue, 04/20/2010 - 01:20
So are you saying I can use ATA's for the phones and link them back to the POTS lines over the network?
Thks
Simon
simonmossman Wed, 04/21/2010 - 07:10
I am still a little confused.......does my last reply make sense?
