Adopting QoS Configuration from C3750 to C4900M
Apr 19th, 2010
I'm suffering on the problem to adopt existing QoS configuration from our C3750 switches to the new C4900M switch series. I'm missing the possibility to compare the existing command with commands I have to use on the new switch. The documentation on the switch is not very helpful for doing this task. If someone could help it would be fine.
This is the current QoS configration used on the C3750 series switches, which I wanted to transform to the C4900M syntax - without success:
mls qos
no mls qos rewrite ip dscp
mls qos srr-queue output cos-map queue 1 threshold 1  4 5
mls qos srr-queue output cos-map queue 2 threshold 1  3 6 7
mls qos srr-queue output cos-map queue 3 threshold 1  1 2
mls qos srr-queue output cos-map queue 4 threshold 1  0
interface gigabitethernet 1/0/1
srr-queue bandwith share 2 3 4 1
priority-queue out
mls qos trust cos
Thanks for helping me
With kind regards
Stefan
Related Content
