vlans help
Apr 19th, 2010
We have 3500 switch in that i have to configure vlans like 10.10.10.10-vlan1,20.20.20.20-vlan-2,30.30.30.30-vlan-3 and iwant all the vlans should be communicated by defalut vlan and i shouls give priority for this vlans like vlan-1 should communicate vlan-3 not for vlan2
plz give me some examples.
srinivas
Giuseppe Larosa Mon, 04/19/2010 - 04:28
  • Hall of Fame,
    Founding Member
Hello Srinivas,
inter-Vlan routing example if you have a C3550 device (not possible with a C3524XL or similar that are only OSI Layer2)
ip routing
vlan database
vlan 2
name vlan2
vlan 3
name vlan3
apply
exit
int vlan1
ip address 10.10.10.1 255.255.255.0
no sh
int vlan2
ip address 10.20.20.1 255.255.255.0
no sh
int vlan3
ip address 10.30.30.1 255.255.255.0
no sh
if it is a L2 only device you need a L2 trunk link to an external device
Hope to help
Giuseppe
vasuramnet Mon, 04/19/2010 - 04:53
Hi sir,
Thanks for ur reply and remote we have dlink l2 switch 3526 how can i made trunk on l2 switch
for this any document is there
Thanks for reply
srinivas
