hello :)
nekaratal
hello, can any one help me about port forwarding on Cisco router 3845 series. im having difficulties viewing my survallance camera outside i can only view it locally here is my config. btw im using static ip but its pppoe.
enable secret 5 $1$mu1x$CMb95/a0gerL2sKkjX72q0
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.0 192.168.10.99
ip dhcp pool mypool
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.2
   dns-server 158.69.254.14 158.69.254.15
vpdn enable
vpdn ip udp ignore checksum
vpdn-group pppoe
request-dialin
  protocol pppoe
interface FastEthernet0/0
no ip address
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface FastEthernet0/1
ip address 192.168.10.2 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
interface Dialer1
mtu 1492
ip address 158.69.142.54 255.255.255.0
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname 270614111
ppp chap password 0 196581111
ppp pap sent-username 27061111 password 0 196581111
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip nat inside source list 1 interface Dialer1 overload
ip nat outside source static tcp 192.168.10.2 8888 158.69.142.54 8888 extendable
access-list 1 permit 192.168.10.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
13 Replies 13
Jennifer Halim
Remove this line:
Change it to this line:
ip nat inside source static tcp 192.168.10.2 8888 interface Dialer1 8888  extendable
Hope that helps.
sir i cant seem to add the extendable command at the last part why is that?
hello, this is the latest config, the one with the ip address  192.168.10.25 and  port 8888 is my dvr.
Current  configuration : 1600 bytes
version 12.4
service timestamps  debug datetime msec
no  service password-encryption
hostname CISCO1841
boot-start-marker
boot-end-marker
no aaa new-model
resource  policy
no  mmi pvc
ip subnet-zero
ip cef
ip dhcp pool mypool
vpdn enable
vpdn-group pppoe
  request-dialin
   protocol pppoe
  no ip address
  duplex auto
  speed auto
  pppoe enable
  no cdp enable
  ip nat inside
  duplex auto
  speed auto
  no cdp enable
interface Dialer1
  mtu 1492
  ip nat outside
  encapsulation ppp
  dialer pool 1
no cdp enable
  ppp chap hostname 27061111
ip classless
ip http server
ip nat inside source static tcp 192.168.10.25 8888 interface Dialer1  8888
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
line aux 0
line vty 0 4
login
end
do i need to put the acces list for the port forwarding?
access-list 101 permit tcp 192.168.10.25 255.255.255.0 eq 8888 158.69.142.54 255.255.255.0 eq 8888
access-list 101 permit tcp 158.69.142.54 255.255.255.0 eq 8888 192.168.10.25 255.255.255.0 eq 8888
You don't need the "extendable" keyword, and you also don't need the access-list.
It should already work now. What's the status?
Can you connect to 158.69.142.54 on port 8888?
umm what do you mean i can connect? 192.168.10.25 is my dvr ip address, 192.168.10.2 is my cisco router and 158.69.142.54 is my ISP address. was thinking is i made a mistake?
You would like to connect to your dvr from the outside/internet, right? That is why you have configured the port redirection?
yes, my i would like to view my survaillance camera from my dvr even when im outside the office.
btw sir one more thing my isp address is static but its a pppoe type, is that a conflict to my config of port forwarding?
No, there is no conflict. As far as the configuration is concern, you should be able to access port 8888 on the public ip address from the internet, and it will be forwarded to 192.168.10.25
yes thats was im thinking why it wont work well going to try still
nekaratal
its working now but only on the HTTP but i can seem to make it work on the DVR software viewer is there any other config for it?
When I was working in the last company, I had a customer who had a similar problem... After weeks of reviewing configurations, sending him different routers, doing a lot of research, and be called not so nice things, the problem was that camera had to be WELL configured, including the gateway with the router LAN IP address. LOL!
I'm not saying you made any mistake, just made me remember about this.
I also guess that this configuration should work...
