IPS upnp signature
Apr 19th, 2010
I have a LAN IDSM in promiscusous mode wherre I'm seing too much of the below alerts, I've researched it and found out that it should be stopped! since it is a high severity alert!! however I guess summarization is preventing me from knowing the attacker and targets because of the 0.0.0.0 source and destination, right? IS  this the case? and how can I solve it?
Should I disable summary for that specific signature? what's the best practice? Should it be stopped?
evIdsAlert: eventId=1262106216512606028  vendor=Cisco  severity=high
  originator:
    hostId: LAN-IDSM2
    appName: sensorApp
    appInstanceId: 25921
  time: Mar 03, 2010 07:38:23 UTC  offset=60  timeZone=GMT+02:00
  signature:   description=UPnP LOCATION Overflow  id=4058  version=S433  type=vulnerability  created=20050603
    subsigId: 2
    sigDetails: LOCATION \x3c100+ Chars>
    marsCategory: Penetrate/BufferOverflow/Misc
  interfaceGroup: vs0
  vlan: 120
  participants:
    attacker:
      addr: 0.0.0.0  locality=OUT
      port: 1900
      ipv6Address: fe80::9d91:b37c:be42:5387  locality=OUT
    target:
      port: 1900
      ipv6Address: ff02::c  locality=OUT
      os:   idSource=unknown  type=unknown  relevance=unknown
  actions:
    denyPacketRequestedNotPerformed: true
  riskRatingValue: 90  targetValueRating=medium
  threatRatingValue: 90
  interface: ge0_7
  protocol: udp
evIdsAlert: eventId=1262106216512606029  vendor=Cisco  severity=high
  originator:
    hostId: LAN-IDSM2
    appName: sensorApp
  time: Mar 03, 2010 07:38:38 UTC  offset=60  timeZone=GMT+02:00
    subsigId: 2
  interfaceGroup: vs0
  vlan: 120
  participants:
    attacker:
      port: 0
    target:
      port: 0
      ipv6Address: ::  locality=OUT
  summary: 24  final=true  initialAlert=1262106216512606028  summaryType=Regular
  alertDetails: Regular Summary: 24 events this interval ;
  interface: ge0_7
  protocol: udp
k.abillama Mon, 04/19/2010 - 07:05
I understand that I have to patch the machines but how can I know what are the machines that should be patches if I'm getting a source and destination ip addresse of 0.0.0.0 on the IPS
If I disable event summary for this specific sig, will I be able to see the source and destination ip addresses?
Jennifer Halim Mon, 04/19/2010 - 14:41
Yes, you are absolutely right. You would need to disable the "summarization" to see the source and destination IP.
k.abillama Thu, 04/22/2010 - 23:07
I removed summarization on a signature basis by forcing it to be fire all instead of summarize but still the source and destionation ip are 0.0.0.0
What could it be? the customer is very picky and asking about it
Please advise
Jennifer Halim Sat, 04/24/2010 - 00:52
Looking back at the event that you have attached earlier, the attacker is using IPv6 address:
racquel.mays Tue, 07/13/2010 - 14:24
Hello all,
Can someone please pick up on the last comment made?  I am seeing the exact same signature in my IDS output with the attacker having an IPv6 ip.  How do I resolve the IPv6 to understand who is attacking me?  From the fe80 I can tell it is a link local ip so the attacker must be from the inside?
