Supervisor roles
Answered Question
Apr 19th, 2010
Hey folks,
Is there a way to increase what roles the supervisor could have through the CRS web page? One of the requests I get
from time to time is to change the assigned skill of an agent from one queue to another.  The agent answers Queue 1 all through the week,
but after hours and on weekends he helps out with Queue 2.
What I am having to do is assign skill 1 during the day, then remove skill 1 and add skill 2 after hours and on weekends.  I do this through the CRS Admin -> Subsystems -> RmCm -> Resources -> "Selected Agent".  If the Supervisor logs into the CRS, IT becomes the Customer Response Solutions Supervisor and has no access to the Subsystems menu tree.
Anyhow, any help would be appriciated.
James
Correct Answer by Anthony Holloway about 7 years 1 week ago
Please use caution and common sense when modifying a production environment!
**EDIT:  Also, if it wasn't obvious already, this is not exactly a documented and supported feature.  Advanced users only please.
You could also modify the AppAdminMenu.xml file to lower the minimum user role on certain menus:
Process:
     1.  Copy C:\Program Files\wfavvid\AppAdminMenu.xml to AppAdminMenu.xml.original
     2.  Edit AppAdminMenu.xml (see example edit below)
     3.  Save AppAdminMenu.xml
     4.  Restart Node Manager
     5.  Enjoy!
Sample Edit to allow Supervisors access to Application Parameters:
This is just a snippet of the entire file
     Applications
          Application Management
          /appadmin/App?request_type=list
          Script Management
          /appadmin/Script?request_type=pgd.root
          Prompt Management
          /appadmin/Prompt?request_type=pgd.root
          Grammar Management
          /appadmin/Grammar?request_type=pgd.root
          Document Management
          /appadmin/Document?request_type=pgd.root
          AAR Management
          /appadmin/AARFileMgmt
Correct Answer by Aaron Harrison about 7 years 1 week ago
If you are on CRS 5.0+, you can set the System Parameter 'Supervisor Access' to 'All' or 'Supervisors Teams Only' to give them access to re-skill.
If you are on an older version... you're stuck.
Aaron
Please rate helpful posts...
Overall Rating: 5 (2 ratings)
Correct Answer
Aaron Harrison Mon, 04/19/2010 - 09:22
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Correct Answer
Anthony Holloway Mon, 04/19/2010 - 09:40
  • Purple, 4500 points or more
Process:
     5.  Enjoy!
     Applications
          Script Management
          Prompt Management
          Grammar Management
          Document Management
          AAR Management
jmhunter Mon, 04/19/2010 - 09:48
Thanks Anthony.  Even though Aaron's answer worked, knowing how to tweek each menu is some really cool information to have as well.
Thanks again,
James
jmhunter Fri, 05/07/2010 - 09:38
Anthony,
Re-visiting this discussion.  When I go to the RmCm menu, and I get the links on the left side (Skiils, Resources, ,,,Assign Skills) How would I modify those links?  It seems that the first five (Skills, Resources, Resource groups, etc) the SUPERVISOR can get to however, to get to the "Assign Skills" link, it requires ADMINISTRATOR access.  That is my goal of what I wish to change.
James
