Upgrade from C2950G-48-EI to C2960G-48TC-L
Apr 19th, 2010
Can a config from a  C2950G-48-EI be pasted into a new C2960G-48TC-L without issue?
The switches in question are in a cluster so I think at the very least those entries would need to be edited out.
I can post config if needed.
Thanks.
Amit Singh Mon, 04/19/2010 - 14:48
James,
Unless its a cluster master, there should not be a problem in adding the new cluster member. I guess both the switches support the switch clustering in their IOS and should be easily configurable. You should be able to copy and paste the config easily.Check for any compatibility issues :
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_fx/configuration/guide/swclus.html
Cheers,
-amit singh
