New 7937G keeps power cycling
Answered Question
Apr 19th, 2010
I have a 7937 hooked up to a CAT3550 and we have PoE runing to that device but it keeps on power cycling. I tried to extend the power on the 3550 by issuing the following command SWITCH#power inline delay shutdown 20 initial 300. All this does is it powers up the 7937 for aprox. 20sec then it goes back to shutdown and tries to power up again.
Any ideas?
Julien
Correct Answer by Rob Huffman about 7 years 3 days ago
Hi Julien,
The reason the 7937 phone does not work with the 3550 is because the 3550 only supports Cisco Pre-Standard Power whereas the 7937 phone only supports IEEE 802.3af power
PoE power snapshot
http://www.cisco.com/warp/public/cc/pd/si/casi/ca6000/prodlit/psnap_br.pdf
7937 Data Sheet
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8759/product_data_sheet0900aecd806e021a.html
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Overall Rating: 5 (1 ratings)
CHRIS CHARLEBOIS Mon, 04/19/2010 - 09:43
  • Silver, 250 points or more
Does it manage to pull an IP address from DHCP?  Does it contact the TFTP server?  I'm seen issues with IP phones that continually reboot because the phone cannot find the right version of firmware to upgrade to.  Although 20 seconds is awfully short for that to be the problem.
julienf28 Mon, 04/19/2010 - 09:47
It might be that it can't connect to the TFTP server as the screen on the devices is "blank". But even then I would assume that there would be some default firmware version on the device that would let you know if you can or can't connect to the server.
J
Correct Answer
Rob Huffman Mon, 04/19/2010 - 10:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Julien,
PoE power snapshot
7937 Data Sheet
Cheers!
Rob
julienf28 Mon, 04/19/2010 - 10:31
Of course, It is good that we are changing our infrastructure from 3500 to 3750 and 2975. Thanks for the info Rob
Rob Huffman Mon, 04/19/2010 - 10:39
  • Hall of Fame,
    Founding Member
Hi Julien,
You are most welcome my friend
Cheers!
Rob
