Regarding PS2 fan issue in Cisco 3745 router
gautamzone
Dear friends,
There is Cisco 3745 router with the following output:
sh env all
Power Supply 1 is  present.
        Fan status:  normal
        Input Voltage status:  normal
        DC Output Voltage status:  normal
Power Supply 2 is  present.
        Fan status:  Warning - failure
48V Power Supply 3 is not present.
48V Power Supply 4 is not present.
Board Temperature: normal.
wcmcq-dial#sh power inline
PowerSupply   SlotNum.   Maximum   Allocated       Status
INT-PS          0         0.000     0.000         PS1 ABSENT PS2 ABSENT
Earlier we were even getting fan rotation syslog messages. However, after they have disappeared but the fan isn't spinning still?
Is it advisable to replace PS2?
Thanks a lot
Gautam
Reza Sharifi
Hi Gautam,
Yes, PS2 apear to be out.  RMA it.
Reza
Hi gautamzone,
Please let me know if the change of PS2 solve your problem.
I'm with the same problem on C3745.
Thank you!
RMA your faulty fan can fix it.
Sent from Cisco Technical Support Nintendo App
