How to tell if CUCM 6.1.4 extensions are off-hook
Answered Question
Apr 19th, 2010
We have all 796x serier SCCP phones registered with CUCM 6.1.4.  From time to time we need to reboot a phone in order to add an extension to the phone.  How can I tell if the phone is in use?
On a gateway router I can do "sh voice call active summary" to get an off/on hook status.  There must be some way to do that with CUCM.
Simply calling the phone doesn't verify anything since the person could be in a conference and simply not answering the call.
Correct Answer by Aaron Harrison about 6 years 9 months ago
Just add it.
If it's in use, nothing will happen until the person hangs up the phone, then the change will apply.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Mon, 04/19/2010 - 13:22
Just add it.
Aaron
Related Content
