FXS Inbound Dial-peer
Answered Question
Apr 19th, 2010
I'm running CME 4.1 with a FXO and FXS ports.
The internal telephony network is running fine, my problem comes when trying to make a call from the PSTN to an anaolgue phone connected to the FXS port.
I can make outbound calls from the analogue phone, I can call internal IP phones etc etc.
When making  call from from the PSTN, I can hear it ring the other end for a couple of times, then I get a secondary dial tone ????
I've tried adding 'connection plar (extension number)' but this seems to bring its own problems - I hang up on the phone from which I've made the call and the analogue phpone connected to the FXS still keeps on ringing.
Here is the config for the voice ports and my dialing plans. 201 is the outbound through the FXO, and 202 and 203 are variations on the same thing to see if I'm not matching the correct string - i've added the stars into the 203 number for security.
Can anyone explain why the secondary dialtone ?
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
dial-peer voice 201 pots
destination-pattern 9T
port 1/0/0
dial-peer voice 202 pots
destination-pattern 260492
direct-inward-dial
port 1/1/0
dial-peer voice 203 pots
destination-pattern 01*08*6*492
Correct Answer by Aaron Harrison about 6 years 9 months ago
Well - the secondary dial tone is entirely normal, as you don't have a way of signaling in a destination number over FXS as you do with digital circuits. When you get that tone, you can probably dial your internal extension number.
The 'plar' command is the correct way to configure this.
The second problem you have - the continued ringing if you hang up - is a problem with disconnect supervision. Basically when the outside caller hangs up, there are ways of signaling this in to the FXO port, but they aren't standard. Depending on your country/carrier they may signal with tones, battery reversal, battery disconnection... so you need to either find out, or do a little trial/error testing to find the right solution.
Try this Cisco doc for some possible solutions (mainly the 'Supervisory-disconnect' commands):
http://www.cisco.com/en/US/partner/tech/tk652/tk653/technologies_tech_no...
If you don't have any luck, try posting back what country/provider you use and someone may be able to point you...
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Tue, 04/20/2010 - 00:32
Aaron
