Multiple Cisco 3560's showing same error : %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port
Apr 19th, 2010
Here is the error that shows in the switch logs:
.Apr 18 03:21:45.939 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_DETECTED: cisco-phone detected on port Fa0/22, port trust enabled.
.Apr 18 12:15:12.651 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Fa0/22, port set to untrusted.
.Apr 18 12:16:07.859 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_DETECTED: cisco-phone detected on port Fa0/22, port trust enabled.
.Apr 18 16:15:20.153 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Fa0/22, port set to untrusted.
.Apr 18 16:16:17.735 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_DETECTED: cisco-phone detected on port Fa0/22, port trust enabled.
.Apr 18 22:28:41.867 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Fa0/22, port set to untrusted.
.Apr 18 22:29:33.056 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_DETECTED: cisco-phone detected on port Fa0/22, port trust enabled.
.Apr 19 07:09:44.035 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Fa0/25, port set to untrusted.
.Apr 19 07:10:41.415 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_DETECTED: cisco-phone detected on port Fa0/25, port trust enabled.
.Apr 19 10:01:43.402 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Fa0/33, port set to untrusted.
.Apr 19 12:52:07.899 MDT: %SWITCH_QOS_TB-5-TRUST_DEVICE_DETECTED: cisco-phone detected on port Fa0/33, port trust enabled.
This error is across multiple switches. The phones(all 7912's) mysteriously reboot and then the computer connected to the phone will get a 169.254.x.x and cannot reconnect to the workstation VLAN through the phone until the computer is restarted.
The phone load is:CP7912080004SCCP080108
Here is an example of one of the ports that is having the issues configuration:
interface FastEthernet0/22
switchport access vlan XXX
switchport mode access
switchport nonegotiate
switchport voice vlan XXX
no logging event link-status
srr-queue bandwidth share 15 20 60 20
srr-queue bandwidth shape  0  0  0  0
priority-queue out
mls qos trust device cisco-phone
mls qos trust dscp
storm-control broadcast level 10.00
storm-control multicast level 30.00
spanning-tree portfast
Anyone have any ideas?
Aaron Harrison Tue, 04/20/2010 - 00:31
  • Community Spotlight Award,
    Member's Choice, May 2015
Could well be a firmware issue on the phones, or a problem with the IOS on the switch. I guess you haven't tweaked the cdp timers on this switch?
Did you notice when this started happening (i.e. after a CCM upgrade, or switch software or config change)?
Aaron
BuckmasterC Fri, 04/23/2010 - 08:37
We recently upgraded Call Manager to v. 7.1.2 from v.5.
I am going to upgrade CM to 7.1.3, hopefully this resolves the issue. I tried upgrading the phones firmware to 8.0.4 and this did not resolve the issue
Jonathan Joson Wed, 01/26/2011 - 14:26
Did your upgrade resolve the issue? We're running CUCM-Business Edition 7.1.5.10000-12 and we are getting sporadic phones rebooting. I've upgraded the phone's firmware to SCCP45.9-1-1SR1S (the phones are 7965s).
The phones also reboot while users are on a call. I've reviewed the SDL traces along with Wireshark captures and can't find much information. I'm working with TAC currently, but they haven't been able to track it down yet either (1 week and going). My next plan is to upgrade to CUCM 8.0(3a).
Thanks for your help in advance!
Related Content
