04-19-2010 04:20 PM - edited 03-15-2019 10:21 PM
Is there a way to increase the number of call history records viewable on the handsets?
For example, it appears that there is a set number of calls that it will store for Placed Calls, Missed Calls, etc. before it starts to over write and we'd like to increase that amount.
Thank you in advance.
Solved! Go to Solution.
04-19-2010 04:46 PM
Sorry, this is fixed. The number is not controlled by CUCM but rather by the IP phone, firmware, etc. Each directory (missed/placed/received) can store up to 100 numbers max depending on the type of phone.
Hailey
Please rate helpful posts!
04-19-2010 04:46 PM
Hailey
04-20-2010 08:03 AM
Got it. Thanks David.
