UC520 EZVPN Client Could not telnet into UC500 Local Ethernet Interface
Apr 19th, 2010
After setup EZVPN for UC500, the vpn client could get IP address from pool. following is the setup
UC520 internal Interface 10.1.1.1/24
define Ip address pool for VPN client as 10.1.1.200 to 10.1.1.210
client connect to UC520 successfully, and acquire IP address 10.1.1.202.
but client could not telnet or ssh into  to 10.1.1.1, and not firewall rules were enable on all interface.
Running KueiLuck-PBX#debug ip tcp packet address 10.1.1.202,
Any thought? Thanks
Get following:
TCP Packet debugging is on for address 10.1.1.202
KueiLuck-PBX#
000639: Apr 19 20:20:54.879 EDT: tcp0: I LISTEN 10.1.1.202:49469 10.1.1.1:23 seq
4234960539
OPTS 12 SYN WIN 8192
000640: Apr 19 20:20:54.883 EDT: tcp0: O SYNRCVD 10.1.1.202:49469 10.1.1.1:23 se
q 2419136075
OPTS 4
ACK 4234960540 SYN WIN 4128
000641: Apr 19 20:20:57.867 EDT: tcp0: I SYNRCVD 10.1.1.202:49469 10.1.1.1:23 se
q 4234960539
OPTS 12
SYN WIN 8192
000642: Apr 19 20:20:57.867 EDT: tcp0: O SYNRCVD 10.1.1.202:49469 10.1.1.1:23 se
q 2419136075
ACK 4234960540 WIN 4128
000643: Apr 19 20:20:57.867 EDT: TCP0: bad seg from 10.1.1.202 -- bad sequence n
umber: port 23 seq 4234960539 ack 0 rcvnxt 4234960540 rcvwnd 4128 len 0
000644: Apr 19 20:20:57.883 EDT: tcp0: R SYNRCVD 10.1.1.202:49469 10.1.1.1:23 se
q 2419136075
OPTS 4 ACK 4234960540 SYN WIN 4128
000645: Apr 19 20:21:03.875 EDT: tcp0: I SYNRCVD 10.1.1.202:49469 10.1.1.1:23 se
q 4234960539
OPTS 8 SYN WIN 8192
000646: Apr 19 20:21:03.875 EDT: tcp0: O SYNRCVD 10.1.1.202:49469 10.1.1.1:23 se
q 2419136075
000647: Apr 19 20:21:03.875 EDT: TCP0: bad seg from 10.1.1.202 --
bad sequence n
umber: port 23
000648: Apr 19 20:21:03.883 EDT: tcp0: R SYNRCVD 10.1.1.202:49469 10.1.1.1:23 se
q 2419136075
Marcos Hernandez Wed, 04/21/2010 - 08:05
  • Blue, 1500 points or more
Does SSH work? Can you telnet from a PC directly connected to the UC500?
Marcos
rawsonfang Wed, 04/21/2010 - 08:44
ssh was not working either, but telnet from local PC on 10.1.1.0/24 segment successfully.
