Shut and No Shut Router Interface at Midnight
Answered Question
Apr 19th, 2010
I have a need to shutdown, wait 30 seconds and issue a no shutdown on a router interface daily at 12am. Is there something that I can automate using Cisco IOS. Please keep in mind that I have no programing or scripting experience. Thanks in advance.
conf t
interface s6/1/1
shutdown (wait 30 seconds)
no shutdown
Correct Answer by Lei Tian about 6 years 10 months ago
If your IOS support, you can use EEM to do that.
An example of shutdown interface fa0/0 @ 12:00 and bring it back @ 12:01
event manager applet TEST
event timer cron name TEST cron-entry "0 12 * * *"
action 1 cli command "enable"
action 2 cli command "configure terminal"
action 3 cli command "interface fa0/0"
action 4 cli command "shutdown"
event manager applet TEST1
event timer cron name TEST1 cron-entry "1 12 * * *"
action 4 cli command "no shutdown"
HTH,
Lei Tian
Overall Rating: 5 (2 ratings)
Correct Answer
Lei Tian Tue, 04/20/2010 - 09:13
HTH,
Lei Tian
davidhuynh5 Tue, 04/20/2010 - 14:28
Lei,
Thank you. That was very helpful. I have two questions:
1. I'm trying to interpet this line "event timer cron name TEST cron-entry "0 12 * * *" but I don't understand how you got it?
2. Is there a "Dummies Guide to EEM" that you can point me in the right direction? I want to learn how to fish.
Lei Tian Tue, 04/20/2010 - 16:29
Cron is the UNIX scheduler, just search on google you will find the syntax and many examples.
For EEM configuration examples, you can search on cisco.com .  Here is one of the configuration example:
     http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6815/config_guide_eem_configuration_for_cisco_integrated_services_router_platforms.html
HTH,
Lei Tian
muhsinamol Wed, 03/09/2016 - 11:32
Dear Lei,
I need your support for this below line
I need to shutdown my interface  APRIL 01-2016  10.1 AM  how we can write the script
Raf
