04-19-2010 06:27 PM - edited 03-11-2019 10:34 AM
Reviewing the release notes and the migration notes - one thing does not seem clear. When you
do the upgrade (via command line or ASDM) - is all the NAT and ACL syntax updated automagically?
Thanks.
http://www.cisco.com/en/US/docs/security/asa/asa83/release/notes/asarn83.html#wp309157
http://www.cisco.com/en/US/docs/security/asa/asa83/upgrading/migrating.html
Solved! Go to Solution.
04-19-2010 07:50 PM
Yes, when you perform the upgrade, syntax from version 8.2 will be automatically converted to version 8.3.
04-19-2010 07:50 PM
04-19-2010 09:57 PM
Great - thank-you!
