Jaime Valencia Mon, 04/19/2010 - 19:05
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM itself cannot provide this, any of the methods involves at least 1 extra server.
CUCM provides an auto-attendant which needs to be loaded into a separate server with CRS, you should have also a 5 agent license.
Other alternatives are to use Unity/Unity Connection/CUE as AA.
More advanced would be UCCX or UCCE.
The question would be: do you have any of the above?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
bawanrajcisco Tue, 04/20/2010 - 18:03
Hi Java,
Thank you for the aswer
We have Unity Connection 7.1 and CUCM 7 We have to Extension (5XX1 or 5XX2) for Customers inquiries. Operators need setup an automated message on the number to assist in answering a few common questions before going through to a telephone operator for an enquiry.
If customers  call for 5XX1 or 5XX2
    “ Welcome to………………..
         If you have a question in relation to your XXX application please press 1
         If you have a question in relation to your YYY application please press 2
        If you’d like to speak to a customer service staff member please press 3”
if 1 is  pressed -   “Customers advise   ……… . If you would like to speak to a customer service officer, please press 4.”
if 2- is pressed   “ Customers advise …………… . If you would like to speak to a customer service officer, please press 4.”
if 3 is pressed - Phone to ring at extensions 5XX1 and 5XX2
if 4is pressed - Phone to ring at extensions 5XX1 and 5XX2
Please give me a guidance to do this
Raj
Jaime Valencia Tue, 04/20/2010 - 19:15
  • Cisco Employee,
  • Hall of Fame,
    2011
There are already plenty of guides on NetPro about how to build an AA on Unity or CUC, I'll tell you the basics and what you need.
CTI RP with CFA to VM
Matching call handler (same DN as CTI RP) where you give them the speech of what options they have.
From that point all you need is 1 call handler for every option you want and to configure them as caller input in main call handler
If you want to immediately send the call to someone configure the caller input to yes, attempt transfer - > respective call handler.
Under the call handler you're sending the call to, set the transfer options to: yes, ring subscriber at this extension -> whatever DN you want to ring
For the option 1 you said you wanted another message, set the caller input to "send to greeting" -> call handler with the message. Then on this new call handler do exactly the same, configure a caller input 4 and send it to another call handler to manage the call.
java
if this helps, please rate
jjoelrichard Wed, 07/20/2016 - 13:24
Hi Jaime,
I'm using Exchange UM services 2010 for Auto Attendant. But that system doesn't allow the caller to provide say variable (other than i.e. dial # for sales) and then use to route the call. Can you advise on a third party app that could do this so I can use CUCM with it?
