04-19-2010 11:08 PM - edited 03-11-2019 10:34 AM
Hi Guys,
My 5510 is running Cisco Adaptive Security Appliance Software Version 8.0(4) .
I have setup some VPN's on this firewall and have been able to access the firewall for management via the VPN using the management-access command
ie. management-access inside
however I had to change the inside interface over to another interface and when I dropped the interface name
no nameif inside,
the firewall drops all references to 'inside'
asa01(config)# show run management-access
management-access
this command should be followed by an interface in the config. So something like
I can’t remove the command either if I do a
no management-access it just says incomplete commandI need to add the “management –access inside” command. But when I do I get the following;
asa01(config)# management-access inside
Please remove the management access before configure a new one
can somebody please help me with this problem and a way around it?
thanks.
Solved! Go to Solution.
04-20-2010 01:40 AM
Yes, seems to be matching bugID: CSCsu89235:
Workaround:
clear configure management-access
Then, reconfigure "management-access inside"
Hope that helps.
04-20-2010 01:40 AM
Workaround:
Hope that helps.
04-20-2010 02:48 AM
Thank you!
That fixed my problem.... I don't know why I didn't think of that :s
cheers!
