UCCX outbound workflow
Apr 19th, 2010
My customer want to send the call varible on an outbound call(manual call not use outbound feature) using IPC Action,
but I'm not sure howto set call variable because outbound call not tie to script so I can't use set enterprise call info
in script.
Anyone has any suggestion?
Tinnakorn
Overall Rating: 4 (1 ratings)
Aaron Harrison Tue, 04/20/2010 - 00:00
  • Community Spotlight Award,
    Member's Choice, May 2015
As far as I'm aware you are limited to the functionality offered by the OB system. There's no scripting, so no real flexibility.
Best you can do is have a CAD workflow triggered when an OB call arrives; theoretically you could use the standard OB enterprise data that the OB system sends to retrieve some information using the built-in browser or other CAD mechanism.
Aaron
whenusayloveme Mon, 06/28/2010 - 21:37
Dear Sir
     I have some question, for the work flow configuration. How can I configur the CAD to pop-up customer's profile when the agent was reserved. Becuase I don't see any option about reserve state to add the action.
     please, suggest
Thank
Winai
Aaron Harrison Tue, 06/29/2010 - 00:17
You should start a new thread for new questions.
'Ringing' is the event you should assign the workflow to - when you go 'reserved', your phone rings, unless your system is badly configured.
Aaron
Please rate helpful posts...
whenusayloveme Tue, 06/29/2010 - 00:34
Thanks Aaron But when the agent was reserved the agent's phone doesn't ring isn't it? it will ring when the agent press accept. I've tested by adding in the ringing state but it still doesn't pop up.
