Internet trafic of remote site redirect through the main site via the ipsec vpn tunel
Answered Question
Apr 20th, 2010
Hi all,
I've a problem to redirect the internet trafic of my remote site to the main site via the IPSEC VPN tunnel. The remote site has a Cisco 2801 router with the ios  (c2800nm-advipservicesk9-mz.124-22.T) and the remote site has the ios (C870-ADVSECURITYK9-M, Version 12.4(15)T12, RELEASE SOFTWARE fc3). this redirection don't work and the  last hop with the extended traceroute form the remote site is the wan ip of the main site.
Is there anyone that can help me to right setup this redirection through the VPN ?
file config of the remote site :
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
crypto isakmp policy 8
encr 3des
hash md5
authentication pre-share
crypto isakmp key dgsn2010 address 41.223.X.X
crypto ipsec transform-set vpn esp-3des
crypto map vpndgsn 10 ipsec-isakmp
description TO HQ
set peer 41.223.X.X
set transform-set vpn
match address VPNHQ
interface FastEthernet0
ip address 41.223.X.X 255.255.255.0
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1300
duplex auto
speed auto
crypto map vpndgsn
interface FastEthernet 4
ip address 192.168.11.1 255.255.255.0
ip nat inside
no ip virtual-reassembly
ip route 0.0.0.0 0.0.0.0 41.223.X.X
ip access-list extended VPNHQ
  permit ip 192.168.11.0 0.0.0.255 any
file config of the main site :
crypto isakmp policy 10
encr 3des
hash md5
crypto map vpncreo 10 ipsec-isakmp
description TO bastos
set peer 41.205.X.X
match address 110
interface FastEthernet0/0
description TO WAN
ip address 41.223.X.X 255.255.255.240
ip nat outside
ip tcp adjust-mss 1492
crypto map vpncreo
interface FastEthernet0/1
description TO LAN
ip address 192.168.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip nat inside source list NAT interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 41.223.31.241
access-list 110 permit ip any 192.168.11.0 0.0.0.255
ip access-list extended NAT
                deny ip 192.168.10.0 0.0.0.255  192.168.11.0 0.0.0.255 any
            permit ip 192.168.10.0 0.0.0.255 any
Correct Answer by Jennifer Halim about 7 years 2 months ago
You would need to configure policy based routing to a loopback so the NAT can be invoked on the main site.
Here is a sample configuration for your reference:
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_configuration_example09186a008073b06b.shtml
Also, make sure that you are not doing any NATing at your remote end, ie: you would need to configure NAT exemption for all traffic from 192.168.11.0/24 to any (Internet).
Hope that helps.
Correct Answer
Jennifer Halim Tue, 04/20/2010 - 03:28
  • Cisco Employee,
Hope that helps.
FONKOU FOSSO Fri, 04/23/2010 - 09:42
Hi Alijenn,
Thanx for your reply !
i've applied the config on my network design and all is working good !!!
these are file for main and remote sites :
Main site :
encr 3des
hash md5
crypto isakmp key dgsn2010 address 41.205.X.X
set peer 41.205.X.X
match address 110
set peer 41.205.X.X
match address 120
set peer 41.205.X.X
match address 130
set peer 41.205.X.X
match address 140
description TO WAN
ip address 41.223.x.x 255.255.255.240
ip nat outside
ip policy route-map VPN-remote
ip policy route-map VPN-INTERNET2
crypto map vpncreo
description TO LAN
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 41.223.x.x
ip route 10.10.11.0 255.255.255.0 41.223.x.x
access-list 110 permit ip 192.168.10.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 110 permit ip any 192.168.100.0 0.0.0.255
access-list 120 permit ip 192.168.10.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 120 permit ip any 192.168.12.0 0.0.0.255
access-list 130 permit ip 192.168.10.0 0.0.0.255 192.168.13.0 0.0.0.255
access-list 130 permit ip any 192.168.13.0 0.0.0.255
access-list 140 permit ip 192.168.10.0 0.0.0.255 192.168.14.0 0.0.0.255
access-list 140 permit ip any 192.168.14.0 0.0.0.255
access-list 144 permit ip 192.168.100.0 0.0.0.255 any
    deny ip 192.168.10.0 0.0.0.255 192.168.100.0 0.0.0.255
    deny ip 192.168.10.0 0.0.0.255 192.168.12.0 0.0.0.255
    deny ip 192.168.10.0 0.0.0.255 192.168.13.0 0.0.0.255
    deny ip 192.168.10.0 0.0.0.255 192.168.14.0 0.0.0.255
    permit ip 192.168.12.0 0.0.0.255 any
    permit ip 192.168.13.0 0.0.0.255 any
route-map VPN-remote permit 10
match ip address 144
set ip next-hop 10.10.11.2
Remote site :
encr 3des
hash md5
description TO HQ
set peer 41.223.X.X
match address VPNHQ
interface FastEthernet4
duplex auto
speed auto
crypto map vpndgsn
interface FastEthernet 0
ip address 192.168.100.1 255.255.255.0
permit ip 192.168.100.0 0.0.0.255 192.168.10.0 0.0.0.255
