Change Audit report inquiry
Apr 20th, 2010
Hi Everyone,
If I just made a new automated action profile under Tools>Change audit and generate a 24 hour change audit report, will it immediately reflect any changes done in the configuration.
Nael Mohammad Tue, 04/20/2010 - 13:02
The automated actions will take effect immediately and will be triggered based on matching criteria you have defined in the rules and the syslog received from the devices.
Ensure that the Automated Action is enabled for it to take effect:
Select Resource Manager Essentials > Tools > Syslog > Automated Actions, then select action and enable.
