Telnet Access Allowed to the Router Even is the Router Process is Over Utilised.
Apr 20th, 2010
Dear All,
Recently had faced a issue in network that when the router CPU utilisation increases or the link is over utilised we cannot telnet into the router.
Kindly help me confuring the routers that even if the CPU is over utilised (if debug is enabled) or the link shokes still we can get telnet access to the router,
or we want to restrict some amount of CPU process to Telnet.
Will scheduler allocate command help here.
Ranjit
Giuseppe Larosa Tue, 04/20/2010 - 03:15
  • Hall of Fame,
    Founding Member
for link high utilization you can use QoS tools like providing some resources to telnet sessions with a dedicated traffic class/queue
For the debug:
you should not enable debug commands if cpu is already at  50%
use a big buffer and configure the device to log only to the buffer
example:
logging buffered 8388608
no logging console
this can help
later you can access the log buffer to see debug messages
Hope to help
Giuseppe
