DMP-Invalid RSS url in 5.2 (Bug discovered?)
Answered Question
Apr 20th, 2010
Hi all,
We have run into the following behaviour.
We sent a presentation with an invalid url to the DMP and ever since we werent able to control it through DMM.
The dmp was not responding to any command sent through DMM (presentations/system tasks)
The only option to bring it back is to restart it through it's web gui.
Is this a known bug?
Correct Answer by Tomas De Leon about 6 years 11 months ago
This is a known issue.
Check out:
CSCte67952 - DMD:  RSS will not work after upgrade to 5.2
Symptom:
The RSS ticker is not showing some content after upgrading to 5.2.
This is because DMD in version 5.2 uses Flash to display the RSS ticker.
And the Flash 9 and 10 player has built in security to not allow content
from another domain.
This security feature is blocking the content.
Workaround:
There are several options available:
1: Only use RSS feeds from sites that allow cross site scripting.
2: Use a service line "Yahoo Pipes" service that acts as a proxy. This
   will result in a a new URL that can be used in the DMD, bypassing
   any cross-site scripting.
Additional Note:
If you use the standard RSS feed in the Signage Design tool, it will work
with any RSS feed you have and you don't need a crossdomain policy file.
Cross Domain refers only to Adobe Flash Player and the ability to read content
from other domains. Its a security issue
As an example:
If your SWF file is hosted on www.cisco.com/flash/myflash.swf
And that SWF want to read any content (xml, rss, etc..) from rss.cisco.com/myrss/xml
That is allowed
If that same SWF file tries to access data on www.google.com/somedata.xml
That would require a crossdomain.xml at cisco.com/crossdomain.xml that lists google.com
This allows the Flash player to access content at google.com
http://kb2.adobe.com/cps/142/tn_14213.html#policy
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
Overall Rating: 4.5 (2 ratings)
Correct Answer
Tomas De Leon Tue, 04/20/2010 - 10:49
  • Cisco Employee,
Check out:
Symptom:
Workaround:
Additional Note:
As an example:
That is allowed
Thank You!
T.
panayiotiscy Wed, 04/21/2010 - 00:05
I 'd like to thank you both.
It seems that we need to set up the rss proxy.
By the way, is there any option to set the speed of the RSS ?
Thank you
panayiotiscy Wed, 06/02/2010 - 01:42
Can someone attache the php_proxy_setup_for_dmd.zip file here?
It seems that the cisco site is down....
Thank you
